tranny cooler
Discussion in 'Technical' started by xpsnake, Apr 18, 2006.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
  2. igo1090
    igo1090 Member
    catonsville, md
    always a good idea to install a trans cooler. if you drive on the street much, i would worry about mounting it in the lower valence because of rocks & pebbles kicked up by cars in front. maybe a piece of black screen or something to protect it a bit. otherwise one rock kicked up the wrong way in the wrong place could have you sitting by the roadside.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I would go with a stacked plate design like the Supercoolers offered by B&M.
  4. Scotty P
    Scotty P Member
    santa rosa, ca
    I have the smaller one. I just posted a pic yesterday on another thread. I mounted it in front of the battery vent behind the grill. Scott
  5. Maverick Man
    California
    any tranny cooler is good. i run both of mine under the valance... i use to run them in the radaitor however i don't like those pins that go though it! even though my fans do... gonna change that though from suggestions form jayman (thanks ;) )
    i have used the one you have like on your link before cuz anything is better then nothing... but i have changed since then to these
    http://bmracing.com/index.php?id=products&sid=3&cat=20&subcat=28
    they are smaller and more cooling area over the other ones. JMO
    but anything is better then nothing... i should know i drive with a 4000 convertor on the street all the time.. sometimes the fwy for a few miles too ;)
  6. Jamie Miles
    I've got mine mounted on the front of the radiator. Works great.
  7. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I have been thinking about going with a long skinny one to put behind the valance.
  8. blugene
    Here's mine
  9. xpsnake
    xpsnake Bruce
    I got a 7x14inch stacked plate style one, going to mount it similar to blugene, but no fan.
