Tranny crossmember for dual pipes
Discussion in 'Technical' started by maverick4925, Jul 29, 2014.
  1. maverick4925
    maverick4925 Rust, Rust and more Rust
    Amelia, Ohio
    1970 Ford Maverick
    When i bought this maverick I noticed the exhaust extremely close to the ground. With straight 6 springs and a 2 leaf leaf pack, the exhaust is literally within 6 inches from the ground. all the time. Before my big ass gets in. So I got under the car and seen the crossmember is of course built for a 6 cylinder car so only one hump for exhaust pipe.
    I've seen double hump crossmembers before, but are they a straight swap between all years of mavericks? maybe just a somewhat quick swap so I can try and get the exhaust packed up closer to the body?
  2. Acornridgeman
    Wisconsin
    Yes, it is a direct swap. Bolts up the same for all years.
  3. maverick4925
    Amelia, Ohio
    1970 Ford Maverick
    Awesome! Thanks for the quick response!!!
  4. mav1970
    I also have a 70 Maverick and they all came with 6 cylinders so you will find that single exhaust cross member in all of them. I bought a double hump cross member but it doesn't fit without some work to it as the 70 tunnel is narrower than the later ones. I gave up and wound up making my own cross member. :)
  5. mav1970
    Mine is actually a 69.5 so maybe that is an issue where it doesn't fit if it is a bolt on for a later 70 :huh:
  6. maverick4925
    Amelia, Ohio
    1970 Ford Maverick
    Well actually, now that you say that, I've seen some other posts here and there that talk about the trans tunnels be different sizes, but I just don't know which are what size. Hell I may look into building one as well if it's too much of an issue.
    And also does your custom member go over or under the exhaust?
  7. Acornridgeman
    Wisconsin
    I've put a double hump in a '70 before without issues, but it was a later car that had an 8" rear. Could be the 69.5 is different since you had a problem making one fit.
  8. 71gold
    my thinking was all 69.5-70s were the same car. the T-5 and Aod crossmembers I sell are 69.5-70 and 71-up...
  9. mav1970
    I took my double hump cross member off of a Comet and the bolt holes did not line up correctly with what was there or seat up against the upper framework right - maybe I should have gotten it off of a Maverick :rofl2:
  10. maverick4925
    Amelia, Ohio
    1970 Ford Maverick
    Does anybody know if there's a difference between a comet and a maverick crossmember? I wouldn't think it's be different, but then again I have no idea.
  11. Craig Selvey
    No difference between the two.
  12. mav1970
    No difference at all - I was only busting :tiphat:
