Tranny Fluid
Discussion in 'Technical' started by Mav Rick, Jan 16, 2005.
  1. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Ok, call me crazy :coco: but I am unsure as to how much Tranny fluid goes in after it has been drained. I put a new filter in and wanted to be sure I had the right amount.
    71 grabber w/302
    Thanks
  2. rayzorsharp
    Since you didn't drain the converter you probably don't need more than 5 or 6 quarts. I'd put in about 3 and just keep adding til it's full checking after each quart.
  3. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    i put in three and the stick keeps reading full :hmmm:
    I bought 5 quarts because i figured thats how much to put in, so i have the extra if it needs it
  4. rayzorsharp
    That may be about all you lost. Be sure to drive it around the block and recheck it. I'm sure you know it needs to be checked while running. The torque converter holds quite a bit of fluid and there will usually be a lot of fluid throughout the tranny that will drain for a long time if left open. If it checks full, then it's full. :)
  5. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    sounds good. Thanks for your help!
    The tranny doesnt slip anymore and the filter has been changed, so I have accomplished what I set out to do.
    --Rick
  6. rap43
    rap43 Member
    Phoenix, AZ
    74 Maverick 4 door, 73 Maverick 4 door, 76 Maverick 2 door
    Related Question.
    What type of Transmission Fluid do you use on an Maverick? Type F ?
  7. don graham
    i use castrol type f. hughes performance transmissions told me that is what they use in all there trannys.:)
