Tranny Pan bolts
Discussion in 'Technical' started by Mav Rick, Jan 17, 2005.
  1. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    As many of you know, I changed out the tranny filter yesterday.
    Half way through putting the pan back on, I noticed that some of the bolts had a really small rubber washer on them. Since not all the bolts had them, so I didnt think anything of it, but today I noticed that the pan is now leaking. Small rubber washers needed or is it something else?
    Thanks!
  2. igo1090
    igo1090 Member
    catonsville, md
    normal bolts usually work fine. was it a cork or rubber gasket and did you overtighten it?
  3. don graham
    my tranny pan dosen't have any rubber washers or anyother washers for that matter. you just have to snug them up. i think only 12-15 pounds. :)
  4. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    I used a rubber gasket. I may have tightened them too much. Does 'too' tight cause it to leak? can it be fixed by just loosening them up or do i need to get another gasket and start over?
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    yeah ovetightening can cause leaks. I assume since you ask....you have a leak?
    I would start all over with another gasket. Leaks can be a real PITA's.
    My Hughes pan came with washers on it
  6. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    yes i have a leak. Ill go ahead and start over. Thanks for your help guys!
  7. don graham
    just looked at the chilton's manual. it says 12-16 ft lbs. good luck,:)
  8. igo1090
    igo1090 Member
    catonsville, md
    if you can find a gasket that looks like thin waxed cardboard (tan or brown color), they are great. impossible to overtighten and seal well.
  9. Phyphor1
    Phyphor1 Member
    1972 Mercury Comet
    Or...
    if you're REAL careful, you can use one of those cork/carboard type gaskets and a little silicone....just be sure to snug it (and don't overdo the silicone, as chunks of it can be sucked up into the filter, )
  10. Cleaver
    Cleaver Member
    MD
    Chel
    Rick - do you have a stamped sheet metal pan or a cast aluminum one? If you have the sheet metal one - hammer the flange around the holes flat - its probably distorted.
    Cleaver
  11. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    all of your ideas will be put to good use. I think i will try and tackle this project today.
    Thanks all!
