trans fluid leak!!!
Discussion in 'Technical' started by random hero, Mar 15, 2009.
  1. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    ok so i noticed some trans fluid leaking, and the fluid is on the back bolts of the trans pan, cross member, and a few other things, but no farther forward than the rear trans pan bolts...i want to say it's the trans gasket, but thats just me hoping...lol. i did have very bad vibrations in the car from bad u-joints, which have been replaced. there is still slight vibration but not to bad. where could this fluid be leaking from?
  2. Mavman72
    Trans pan gasket...speedo cable...tail shaft housing gasket...end seal at driveshaft yoke...
  3. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    dipstick tube...
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    All very good possibilities.
  5. lika
    lika SeƱor Comet
    IA
    comet 71
    metal hoses from around the transmission
  6. 71gold
    i think...the bad u-joint beat the ...tailshaft bushing and seal...to the point it vibrates and leaks...
    ...or time to replace the washer bottle fluid...
    ...:yup:...
  7. random hero
    hudson valley
    1972 maverick
    how easily is that changed...you really think it's the tail shaft housing seal? the substantial amount of fluid is at the rear of the trans pan, much further forward from the tailshaft housing...any ways to tell? my speedo cable has been squeaking a whole lot in my dash. atleast i got a few places to check, thanx for all the help guys, hopefully i can get all of this figured out soon :drive:
  8. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Best way to tell is put up in the air on a lift or 4 Jack stands
    Clean all the old fluid off with a good cleaner like Brake clean.
    Start Car put in gear and start watching for the leak.....
    It may take a bit but it should be visible after a while...
  9. PaulS
    It would also help to pinpoint the leak if you use a black light (UV).
    The transmission fluid will glow in the black light and you can trace it right to the leak. Just remember that the oil will always flow down or across but rarely up. That means the leak is from the highest place you see the oil.
  10. scooper77515
    Cool! I never knew about trans fluid glowing under UV light! Great idea.:thumbs2:
  11. random hero
    hudson valley
    1972 maverick
    i found it, it's one of my cooler lines, i guess it rattled loose, i put in an external cooler (went to take the radiator out and the lines were so rusty i just cut them and flared them) b/c it has the rubber lines do u think it will rattle loose again, or were the bad u-joints the more likely cause. thanx for all the help guys
  12. PaulS
    Did you use 200 psi hose to connect the lines? If you used fuel line then get some transmission cooler hose and put that on instead - FAST! fuel line will not hold the cooling pressure for long and when it fails it will drain your transmission fast.
    The rattle and vibrations of driving down the road - in addition to the bad joints could be the cause. The easy fix is to coat the threads and tubing flare with Loc-Tite or Permatex 518 sealant and then tigten the fittings.
  13. sierra grabber
    sierra grabber Certifiable
    northern nevada
    that is one of the pain points i am trying to get sealed as well. also you may want to check the band adjustment bolts directly beneath the rear cooler line as they have a tendancy to drip a little. also the shifter shaft and kickdown.
  14. PaulS
    If you loosen the band adjustments you may need to replace the lock nuts because the seals on them don't like to be disturbed and the seals are not replaceable.
  15. random hero
    hudson valley
    1972 maverick
    i bought the cooler from napa, it came with all the proper hardware, also, it took me much longer than expected to fix the leak. there was no room to fit the wrench in....i had to take a grinder to 2 of my wrenches...first one was the wrong size...lol.
