trans gasket
Discussion in 'Transmissions' started by royboy88, Oct 15, 2012.
  1. royboy88
    royboy88 Member
    decatur il
    77 ford maverick, 69 ford custom 500, 94 ford explorer
    Does anyone know if the still make the cork transmission gaskets I replaced mine with a rubber gasket and it is still leaking around the edges
  2. junrai
    junrai Member
    rancho cordova ca
    if your pan isnt new maybe it is bent a little try replacing the pan or ball ping hammer the holes flat if theyre bent up. you can use black sealer and it wont leak. that stuff is beyond sealer its like a crazy sealer. I used it on my oil pan and when I had to take it back off I didnt think I was going to get it off in one piece. that stuff holds like its life depends on it
    as far as your question goes I dont have the answer
  3. Craig Selvey
    You can also have the bolts too tight, which will distort the pan around the bolt holes.
