trans mount info needed
Discussion in 'Technical' started by spork1o1, Mar 13, 2007.
  1. spork1o1
    spork1o1 Member
    Michigan
    I was test fitting my small block and toploader in the car yesterday, and looks like my trans is a little to close to the top of the trans tunel. Are there diferant thickness trans mounts avalible? The one I have now is for a 67 mustang.
  2. stonecoli
    stonecoli Member
    Los Angeles, CA
    none
    Seems like no one's interested to reply to your post. Dun know if I could help. :(
    I think the tranny mount will fit perfectly if you buy one that's intentionally made for the tranny parts. Its thickness will depend on its parts. I used to have Mercedes transmission mount perfectly fit for my old car before I sold it then switched to comet. :cool:
  3. Mavaholic
    As I recall I bought mine from a Mustang place. They are all alike. I am also running a toploader.
  4. spork1o1
    spork1o1 Member
    Michigan
    how close is the top rear corrner of the top cover, to the trans tunel on your car?
  5. stmanser
    Davenport, Iowa
    spork.. show us some pics as to what you mean...
    there is only 2 tranny cross members... 1 hump and 2 hump.. both are identical in size, and placement of the tranny.. only difference is the dual hump is for dual exhaust..
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The rubber mount is the same as a Mustang. Are you running a Maverick Crossmember?
  7. spork1o1
    spork1o1 Member
    Michigan
    Yes I am useing a maverick crossmember, and a mustang rubber mount.
    when I install the mount between the crossmember and trans, I only have 1/4 inch clearance at the top of the trans. ( red arrow). (at the back of the top cover plate not the tail shaft)
  8. stmanser
    Davenport, Iowa
    1/4 is close, but no unreasonable.. if it isnt hitting its fine.. with engine torque, im not sure if it will hit.. only one way to see, torque it.. and drop the tranny a little and see if there is rubbing
    otherwise you could weld the holes where the bolt goes through the frame and re drill new holes to lower the tranny another 1/4 to 3/8 of an inch
  9. Mavaholic
    I can't get to my car right now to check it out. I know it is close in a couple of areas but not enough to worry about. I have driven the car pretty hard and nothing has hit yet. You will also need a Mustang speedometer cable. The Maverick one is too short to reach the right side. I believe I got one for a 70-72 with 4 speed.
