Trans Question
Discussion in 'Technical' started by MarulMav, Oct 4, 2005.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Hope this takes care of your problem, That is what is great about the fourm solving problems. Dean
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    The valve goes first then the spring ,be sure to NOT use too heavy a grease to help hold in position,you may be able to install a filter screw(loosely),so the filter will turn(like the hands of a clock) and slide over the check valve spring...
  3. hotrod-daddy
    hotrod-daddy Member
    I couldn't have said it better than Dean, we are all here in this forum to help each other.....Hotrod-Daddy
  4. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    Will heed your advise. This forum is great!!!
