trans tunnel
Discussion in 'Transmissions' started by seth, Jul 16, 2009.
  1. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    on my 69 mav i am in the middle of swaping in my 302, will i have trouble with the 302 belhousing fitting in the transmission tunnel because of it being narrower then the rest of the years
  2. Earl Branham
    Lugoff, SC
    Seth; if you use the C4, the bell and trans will fit ok. If you use an AOD or a T5, you will have to trim the tunnel supports above the front of the trans, and modify or use a different crossmember. The trans tunnel is narrower on the 69.5, and the crossmember is a challenge. Everything else is the same. Good luck!
  3. Jamie Miles
    Yep, like Earl said, C4 will fit fine. If you use the double hump transmission crossmember, you'll have to drill a new hole on one side to bolt it up.
  4. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ok sounds good im using the c4 so it should be good
  5. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    hay do you guys know were i can get the spacer plate that fits between the engine and belhousing the one i got with the engine is from a different trans and dosent fit so well can u get them online?
  6. Earl Branham
    Lugoff, SC
    Seth; I may have one. I'll check tomorrow and get back to you on this thread.
  7. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    that sounds good if u have one for an automatic that would be great, o and which side is the side that needs to be drilled out for the double hump support to fit.
  8. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    jamie... i have a 70 and the hole for a double hump crossmember is already there.... when did they start doin that?
  9. nickmav70
    Dallas, GA
    1971 Ford Maverick
    and it would be the drivers side because the passenger side is already higher for the exhaust
  10. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    ya the 70 is different then the my 69 so the the driverside needs moverd up then
  11. Earl Branham
    Lugoff, SC
    Seth; I have a block plate if you need it. Just pay the shipping (about $20???) and I will send it to you. Send me a pm if you are interested, and we can get it done there. Let me know!!!!!
