transbrake...
Discussion in 'Transmissions' started by 71gold, Sep 14, 2008.
  1. 71gold
    got the transbrake switch installed yesterday...
    going out and test it today....yes!!!...in the street...:chirp:
    ILM: AOD,RDB,RSP,AC,CTB,DDG,AR,TEF,MSDD,H600,RFWK,SFCs, 6A,AFRs,DT,TB,???,MS...(y)
  2. mavmike72
    mavmike72 Member
    louisville kentucky
    how does a transbrake work ?
  3. 71gold
    ...:huh:...let me go try it out and i will let you know...:yup:
    i've never had one before...
    i just got it for the...WOW...factor...:chirp:
  4. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    (y)We need video.There will be lots of tire smoke after the release.
  5. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    A trans brake works by locking the trans in first and reverse at the same time, causing it to basically be in park while the button is held. Upon releasing the button it goes into the low gear. This way its like a linelock so you cant go forward or backwards but you can build up RPM and be in its optimum power range when it launches.
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I didn't think it was good to run a trans brake on the street? All of them I ever saw advertised said "Not for street use" :huh:
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    It's probably not the best thing to use on the street, but it all depends on how hard you bang on it. Just like dumping a clutch or neutral dropping it, neither are the best thing to do.
  8. don graham
    It doesn't do anything unless you push in the button. Definitely helps on the launch in a race car. So far I've always been a footbraker. However it is legal in my sportsman class here in Division 7. It is harder on parts in the tranny though.:)
  9. Andysutt
    Conway Arkansas
    1972 Comet GT
    Yes, I forgot to mention that it doesnt do anything unless you actually use the button. Sorry if I confused anyone.
