Transmission Automatic Problems
Discussion in 'Transmissions' started by Speechless35, Apr 21, 2013.
  1. Speechless35
    Speechless35 Speechless35
    Naples,Fl
    1976 Ford Maverick Sedan
    Driving my car yesterday with no problems. 76 Ford Mav Inline 6. Today I start driving and it just takes so long to go into second gear? I added fluid because I was a little low... How do I fix this problem?
  2. 71gold
    did it do better after adding the fluid?
    sounds like a vac. leak in the line going to the modulator valve or the valve itself.
    see if there is fluid in the line.
    Frank
  3. Speechless35
    Naples,Fl
    It did a little better after the fluid but its still acting up a bit. I put two quarts and my dipstick told me it has fluid. Should I have added the fluid while the car was running or when the engine was cold??
  4. mercgt73
    mercgt73 Member
    Automatic transmission fluid is checked on level ground, at operating temperature, engine running and in PARK.
  5. Speechless35
    Naples,Fl
    And I did. Just don't know why it's taking a while to get to second gear...
  6. rthomas771
    Two quarts is a lot of fluid. I don't see how it could still be working at all if it was that low.
  7. Speechless35
    Naples,Fl
    I meant two bottles. And the dipstick says its perfect
  8. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    What Frank said X2.
  9. Speechless35
    Naples,Fl
    Apparently is what almost dry and when I added fluid it filled it. I checked my dipstick many times over running and not running and it's not over. Lets see how it drives thus afternoon
  10. 71gold
    I'm thinking 2 bottles is 2 quarts...:yup:
  11. simple man
    simple man Member
    Bunnell,Florida
    Make sure to only use fluid marked " type F ". You must check the fluid after driving at least 10 miles. Overfilling these transmissions can cause damage! As was said before, engine completely warmed up, idling in Park, on a level surface! If you have to check it cold, engine idling, fluid should just touch the bottom of the dipstick. This fluid expands greatly as the temperature goes up! :)
  12. Speechless35
    Naples,Fl
    Found the problem. Shifting hose was brittle and worn. I put a new one on and just like that the shifting is back to normal
  13. simple man
    simple man Member
    Bunnell,Florida
    Good news! There is another one that goes from the modulator to the metal tubing. It is underneath the car at the rear of the transmission. You should replace it also. :)
