transmission/bolt torque specs
Discussion in 'Transmissions' started by Flinn, Jul 22, 2015.
  1. Flinn
    Flinn Flinn
    Idaho
    73 Maverick
    Hey guys I have a 351w to c4 setup I'm trying to install and I need to know some bolt torque down specs. They are transmission mount to transmission, transmission mount to crossmember. Motor mount to frame mount, and motor mount to engine block. Thanks for any help.
  2. dyent
    dyent Member
    vancouver bc
    tranny mount to tranny 40-60 ft/lbs.
    tranny mount to crossmember 30-50 ft/lbs.
    motor mount to frame mount 20-30 ft/lbs.
    motor mount to engine 35-60 ft/lbs.
    specs from Ford Service Manuals, use oil or anti-seize on threads.
    David
  3. 71gold
    so all of them could be...40 ft/lbs...:huh:
  4. junrai
    junrai Member
    rancho cordova ca
    all of that stuff we just tighten real good and thats it. weve never had a problem
    Ive never thought about the torque specs on those parts always just thought they had to be good and tight
  5. Flinn
    Flinn Flinn
    Idaho
    73 Maverick
    Thank you dyent. Originally i was just going to make them real tight but would rather have them torqued to specs.
  6. 71gold
    ...motor mount to engine 35-60 ft/lbs...
    with this torque spec. what are you going to torque it to...:huh:
    don't forget to have your torque wrench calibrated before you start...:yup:
  7. dyent
    dyent Member
    vancouver bc
    I would just go and use a setting in the middle along with lube/anti-seize and you'd be good to go.........
    David
  8. 71gold
    why does Ford give such a wide range for torque specs, we are using a persision calibraded tool?
    some of my LSX torque specs.
    Cylinder Head Bolts (M8 Inner Bolts in Sequence) 22 lb ft
    Cylinder Head Coolant Plug 15 lb ft
    Cylinder Head Core Hole Plug 15 lb ft
    Drive Belt Idler Pulley Bolt 37 lb ft
    Drive Belt Tensioner Bolts 37 lb ft
    Engine Block Coolant Drain Plugs 44 lb ft
    Engine Block Heater 30 lb ft
    Engine Block Oil Gallery Plugs 44 lb ft
    Engine Coolant Air Bleed Pipe Bolts and Studs 106 lb in
    Engine Cross member Bolts (Large) 107 lb ft
    Engine Cross member Bolts (Small) 92 lb ft
    Engine Flywheel Bolts (First Pass) 15 lb ft
    Engine Flywheel Bolts (Second Pass) 37 lb ft
    Engine Flywheel Bolts (Final Pass) 74 lb ft
    Engine Flywheel-to-Torque Converter Bolts 44 lb ft
    Engine Front Cover Bolts 18 lb ft
    Engine Mount Heat Shield Nuts 89 lb in
    Engine Mount Stud-to-Engine Block 37 lb ft
    Engine Mount Through Bolts 70 lb ft
    Engine Mount Through Bolt Nuts 59 lb ft
    Engine Mount-to-Engine Block Bolts 37 lb ft
    Engine Rear Cover Bolts 18 lb ft
    Engine Service Lift Bracket M10 Bolts 37 lb ft
    Engine Service Lift Bracket M8 Bolt 18 lb ft
    Engine Valley Cover Bolts 18 lb ft
    Engine Wire Harness Clip Bolt 37 lb ft
    Engine Wire Harness Ground Strap Bolt 37 lb ft
    Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass) 89 lb in
    EGR Valve Bolts (Final Pass) 22 lb ft
    EGR Valve Pipe-to-Cylinder Head Bolts 37 lb ft
    EGR Valve Pipe-to-Exhaust Manifold Bolts 22 lb ft
    EGR Valve Pipe-to-Intake Manifold Bolt 89 lb in
    Exhaust Manifold Bolts (First Pass) 11 lb ft
    Exhaust Manifold Bolts (Final Pass) 18 lb ft
    Exhaust Manifold Heat Shield Bolts 80 lb in
    Exhaust Manifold Pipe Nuts 26 lb ft
    Front Shock-to-Engine Cross member Bolts 48 lb ft
    Fuel Injection Fuel Rail Bolts 89 lb in
    Generator Bracket Bolts 37 lb ft
    Generator Rear Bracket-to-Engine Block Bolt 18 lb ft
    Generator Rear Bracket-to-Generator Bolt 18 lb ft
    Ground Strap Bolt (at Rear of Cylinder Head) 37 lb ft
    Ignition Coil-to-Bracket Bolts 106 lb in
  9. 71gold
    why do you have to guess what the right torque number is?
  10. dyent
    dyent Member
    vancouver bc
    who knows with Ford, all those specs where right from their 5 volume Shop Service Manuals that I have for 1974. Even my 68 Service Manual for Mustang had a range, but within 10 ft/lbs, perhaps they where covering for different bolt grades from 2 to 8....after looking at the chart below, kind of makes more sense now.
    Here is link to site with torque specs for bolts:
    https://www.boltdepot.com/fastener-information/bolts/US-Recommended-Torque.aspx
    site also has chart for markings of various grades etc.,
    David
  11. 71gold
    I kinda see your thinking but...they know what size/pitch the bolt is for the application so still ...why the 25 ft/lbs range?
    even at that the bolts listed for the motor mounts are 3/8" grade 5 and the torque for them are are only 3 ft/lbs from Course-Fine ( not 25 ).
    my motor spec... Mount-to-Engine Block Bolts 37 ft/lbs...M10x1.5 (3/8" = 9.525 m/m)
    sorry...this has always been a pet-peve of mine...:bouncy:
  12. dyent
    dyent Member
    vancouver bc
    I found this way back when I was doing my Machinist Apprenticeship 35 years ago, see the notation below the chart, especially #2. (sorry about chart being on its side.......)
    Also, the motor mount to engine block bolt is 7/16 - 14 with 4 center marks, which would indicate it is a grade 6 bolt and using the chart below, 55 ft/lbs. the threads are also triangular shape (not round) which acts as a locking type device. Even those tranny mount to crossmember nuts are Flanged/Stover nuts are again triangular shaped to act as locking nut. So when one starts taking into account grade of bolt 5,6 or 8, using lube or not etc, etc., yes, I can see why there is such a range........
    I would just go and use the chart below, check bolt thread size, grade and cross reference with torque spec and Bob's your uncle........
    David
  13. 71gold
    my point...Ford Motor Co. knows what type of bolt that is being used in each application, so why give such a broad range torque spec?
    agree the chart tell us what to torque each of the different bolts but Ford chose the 7/16" bolt for... the motor mount to engine block bolt...:huh:
    referring back to my specs, they only give one setting...they know what bolt is being used...:yup:
  14. dyent
    dyent Member
    vancouver bc
    guess that is something only Ford can answer? who knows what the thinking was 40+ years ago!
  15. Flinn
    Flinn Flinn
    Idaho
    73 Maverick
    Sorry been off here for a few days. Will definitely look into specs more as i dont want to screw up. Thanks 71 gold and everyone else.
