Transmission fluid
Discussion in 'Technical' started by wolfheads, Apr 25, 2015.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I just drained the fluid from my c4 tranney and replaced the filter, How many quarts does it need?
    Thanks
    1973 Mav 302
  2. 71Mavrk
    71Mavrk Member
    Nevada
    Per Chilton, it is 18 pints but it is not stating if that includes the converter or not.
    Micah
  3. Craig Selvey
    Put a few quarts in, then start the car and leave it running while you put in the rest. Keep checking the dipstick.
  4. Krazy Comet
    If you drained only the pan it's maybe three or four quarts, if you drained converter as well total should be 9 quarts for a V8 transmission(converter is larger than 6cyl)...
    Assuming dry, add no more than five quarts then start engine and add remainder...
  5. Rasit
    Rasit Member
    SE Pennsylvania
    X2. Three to four quarts. Just finished a rebuild with an 10" converter and it took a total of 7 1/2 quarts.
  6. 71gold
    I have a clear 1 gal. plastic jug I drain my transmission fluid in. I can gauge by that how much to replace. the clear jug also lets me see any sediment in the fluid by letting it set overnight.
    note: the longer you let it drain the more it takes to refill. it will drain half the converter if left over night.
  7. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    I have a hard time getting a true reading on my transmission fluid .Is there something I can put in the pan to keep fluid from splashing back on the dipstick
  8. 71gold
    there shouldn't be any "splashing"...where the reading is the stick is submerged...
  9. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    I have a trick flow pan and Ford Motorsport dipstick.
  10. 71gold
    still...there shouldn't be any "splashing"...where the reading is the stick is submerged...
