Transmission in sideways..........
Discussion in 'Transmissions' started by nickmav70, Dec 24, 2009.
  1. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    ok i just installed my t5 and.... its sits further to the drivers side than it does in another persons car... both mavericks... both early models 69.5 and 70... same crossmember... crossmember fits his... but with mine the transmission sits too far to the drivers side by about an inch... anybody know why?
    both are wc t5s
  2. Jeff S
    Jeff S Member
    NoVA
    none
    Worn motor mounts or tranny mounts?
    Im guessing if the driver side motor mount is bad it could tilt the entire engine to one side, causing the tranny to tilt too...is it tilted or actually moved?
  3. nickmav70
    Dallas, GA
    1971 Ford Maverick
    Both are brand new... Maybe just low quality? Got them from autozone
  4. 71gold
    :hmmm:...just a shot-in-the-dark but are the frame stands on the correct side?
  5. Jamie Miles
    Both your frame mounts have the offset facing to the rear?
  6. Jamie Miles
    Frank beat me to it. :rofl2:
  7. nickmav70
    Dallas, GA
    1971 Ford Maverick
    Yes frame stands are on correct
  8. PaulS
    If the engine is straight in the mounts then you do not have the transmission seated on the bell or the bell is not seated on the emgine.
    If they are all seated correctly then either the engine is not sitting correctly or the cross member is not in correctly.
  9. 71gold
    here's a pic. of Earls, maybe someone can help from there...:yup:
  10. nickmav70
    Dallas, GA
    1971 Ford Maverick
    Everything is fully seated and properly installed... Only thing I can think is defect motor mounts:hmmm:
  11. nickmav70
    Dallas, GA
    1971 Ford Maverick
    Thanks everyone.... And merry Christmas :thumbs2:
  12. Jeff S
    Jeff S Member
    NoVA
    none
    Im trying to figure out how its sitting...
    does the motor sit exactly like this? The valve cover is completely vertical...if its not vertical then one of the motor mounts are bad or mounted incorrectly ...if it is vertical then something is wrong with how the transmission is mounted
  13. rthomas771
    I think it's sitting more like this.
  14. Jeff S
    Jeff S Member
    NoVA
    none
    :biglaugh:
    I actually looked at it for a moment :biglaugh:
  15. nickmav70
    Dallas, GA
    1971 Ford Maverick
    It is angled left to right between the frame rails so that the very end of the transmission is offset to the drivers side by about an inch or an inch and a half
