Transmission oil pan question.
Discussion in 'Transmissions' started by Racer_X, Aug 16, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    does using a transmission oil pan that has an extra 1qt capacity really help lower fluid temps?
  2. Joe Dirt
    Yes, more fluid takes longer to heat
  3. 71gold
    I agree with the gentleman from Tenn...:yup:
  4. Racer_X
    North Carolina
  5. olerodder
    olerodder Member
    NorCal
    I think you can use a stock filter.....................at least on my Street Fighter PA trans with deep pan it used the stock filter.............................but I would check with PA since they made the pan, or call Summit...............IMHO
    http://www.performanceautomatic.com/index.php
  6. Racer_X
    North Carolina
    I went ahead and got a deep transmission pan filter just in case.
  7. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    You can get a filter for a V8 Mustang II. They had deep pans on them from the factory.
  8. 71gold
    a stock filter will be fine...:yup:
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    If you get the B&M pan it comes with a filter extension and an actual filter(not just a screen)..... They are a little more expensive then the others but well worth it.....
  10. 2mav4u
    Tolleson Az
    I have a 1970 Maverick with a 200 and c4 all stock.
    How can i find out if i have a regular trans pan or a narrow pan?
    I ask because im going to change my trans filter and apparently their are 2 types of filters.
  11. 71gold
    I've never heard of a...narrow pan...just pan fill and case fill.
    ...:huh:...
  12. Racer_X
    North Carolina
    think he means shallow or deep pan. a stock c4 should have a shallow pan
  13. 2mav4u
    Tolleson Az
    Yes shallow. I couldn't remember the correct name and thank you.
  14. 71gold
    there shouldn't be but one choice for a...'70 C-4...:tiphat:
  15. 2mav4u
    Tolleson Az
    which is??? :hmmm:
