Transmission removal
Discussion in 'Transmissions' started by Eddie Maverick, Apr 8, 2008.
  1. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Looks like a got a bad front seal on the C4. It shifted into gears, but when I shut the car off I noticed a steady stream of fluid coming from the bell housing area. Really frustrating since I just got everything running, kind of a setback really.
    My question is, can the tranny be removed easily enough without removing the headers? I really don't want to go thru that hell again if I can avoid it.
    I figure I'll get the transmission out and inspect it, buy a seal kit and new pan gasket and hope all is good. I don't think the TQ converter is cracked, but I'll have to give that a close look too.
    May as well do a shift kit while it's out, then not have to deal with it again for a while.
  2. 71gold
    i have had to loosen the header bolts to get wiggle room...:yup:
    ...it will be messy...
    ...Frank...
  3. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Yeah maybe I can just loosen the passenger side, since it's the easier side to deal with.
    Definitely gonna be messy, but hopefully worth it. I'm just mad that I have to do it at all.
  4. 72CometGT
    72CometGT Member
    Atlanta, GA
    Green 72 Comet GT
    not sure on pulling it, but I couldn't tighten down my headers until I had the trans fully installed b/c of interference.
  5. yellow75
    Tillamook Oregon
    It can be done but is real pia, got to turn it about 90 degrees and cuss then turn it 30 more degrees then rest your arms walk away from car cuss some more then swear you are never going to do this again, then crawl back under car into puddle of tranny fluid lay there for awhile and stare at everything under the car then get the idea to call a friend to help out, much easier with help, then you get tranny out and find out you just put too much fluid in it arrrgh. No I am not speaking from experience about too much fluid but know of others that did
  6. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    You know Mike I'd hate to find out that it was just too much fluid, that would really PMO! LOL
    From the indication on the dipstick it doesn't read full. But heck now you got me thinkin. Is there any other way to make sure I didn't overfill it besides the dipstick?
    Also would it leak from the bellhousing from being overfilled?
    How can I get all the fluid where it's supposed to be? Jack it up and let the wheels spin for a while?
  7. 71gold
    "crawl under"..."lay there"...:huh:
    ...:D...
  8. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Rub it on in Frank :D
    I only wish I had that in my garage/shop/storage shed/washroom. LOL
    Maybe one day, but for now It's up on stands ready for me to crawl under it and lay there cussing up a storm.(y)
  9. PaulS
    When you install the new seal be sure to lubricate it (especially the sealing surface) so it doesn't burn the seal edge up before it can get enough oil to stay lubed.
  10. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    good advice, thanks Paul
  11. don graham
    One of the best investments I've made was a tranny jack from Harbor Freight. I think it was about $50 (on sale). Definitely makes it easier to take out and replace. It's not top quality but it'll do for a guy that only needs it once in a while.:)
  12. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Yeah I was just on the harbor site earlier today looking at one. i may just make that run tomorrow.
    Thanks
