Transmission supply/return lines or hoses to radiator
Discussion in 'Transmissions' started by alaskamaverick, Jun 26, 2015.
  1. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    Can one use transmission hose (Armor Mark/Transmission cooler hose) instead of hard steel lines?
  2. rthomas771
    The factory did it all the time back in the 60's
  3. Rasit
    Rasit Member
    SE Pennsylvania
    Steel lines will run cooler and maintain constant pressure/flow characteristics. With that being said, yes one can run whatever kind of lines he wants and the fluid will get there....
    Krazy Comet likes this.
  4. Krazy Comet
    Agreed, plus for OEM it' s more expensive to use molded hose vs steel, which is really what would be required in many instances...
  5. 71gold
    I use hydraulic hose...:thumbs2:
    Richard Kuss likes this.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    The other thing to consider is longevity, the hose will breakdown over time and start to leak or completely fail. If you do steel lines they will last a lot longer (properly routed and supported) than the hose.
    In some of our training material they give a life cycle of hydraulic hose, the steel braided, high pressure stuff and it is rated to last "40 quarters" or ten years. That is a much different hose than what you buy for a trans line, that hose only has a useful life of 3-7 years depending on the conditions it's used in.
  7. alaskamaverick
    Spokane, WA
    ok, steel lines it will be. Where does one find them, or should they make them?
  8. Craig Selvey
    www.RightStuffDetailing.com has them. Prebent and ready to go.
  9. alaskamaverick
    Spokane, WA
    Thank you Craig
  10. baddad457
    You can adapt the newer stainless lines found in the J'yards off the late model picks and vans for this too. I did this on mine using a set of lines off a wrecked 92 E150, the bends are pretty close to fitting as they are. Just needed a little tweaking to make em work.
  11. alaskamaverick
    Spokane, WA
    I was thinking about doing that, (not really) thanks for the idea...I know a J"yard that has a few older Fords
