Transmission Talk
Discussion in 'General Maverick/Comet' started by Renton5, Jun 19, 2014.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hello, I have a '71 Maverick, 200 engine, C4 automatic trans. Well, its leaks are getting prominent. It's never been overhauled (as far as I know), has some 128,000 on it. On a scale of 1 to 10, with ten being, "Aaaack! Don't even think about it!", how hard is it to rebuild?
    Thanks for the advice!
  2. 71gold
    with...a book, right tools and skills...(1)...:yup:
  3. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    To rebuild a c4 I give it a 2 out of 10. It's very easy with a book.
  4. Craig Selvey
    If you have no mechanical experience what-so-ever....a 10.
  5. Renton5
    Renton5 Member
    Van Nuys, CA
    From what I've seen, once the trans is on a workbench, it shouldn't be too hard, but the hard part is removing it, since I don't have the means to raise it much higher than to slide under the car. Also, I'd want to replace all the gears, or at least the ones that have obvious wear on them. And all that fluid! It'll look like a battle scene from "Game of Thrones", if I'm not careful! Thank you all for your advice and comments!
  6. jtown77
    jtown77 Member
    Arizona
    71 Comet
    What's your budget? Monster transmission would run you about $1100 for a rebuilt one delivered to your door.
    Tools would be one problem.
  7. Krazy Comet
    Unless it had a mechanical failure gears are almost never worn in a automatic that's behind a low HP engine, the seals, clutches and bands are what fail...
    Find a exploded view on line to see if you want to tackle it, without some assistance/guidance no automatic is a job for someone with little or no experience... I rebuilt a couple back in the '80s but probably wouldn't attempt it now(yes they worked and didn't leak)...
