transmisson fluid
Discussion in 'General Maverick/Comet' started by nateambriz, May 10, 2011.
  1. nateambriz
    nateambriz Member
    Lacey, WA
    70 Maverick
    my engine is a 200 and I feel completely dumb for asking this question but where does the fluid go? I know where the dipstick is and everything.
    Also, my tranny is leaking fluid from the cool lines that connect to the radiator. I dont have the time to do this myself or with a bud, so how much would something like this cost to replace?
    thanks.
  2. rthomas771
    The fluid goes down the dip stick tube. The fittings might just need tightening. The cost could be anywhere form $0 - $200 or more
  3. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Make sure you check the trans level with the engine warmed up and idling in park or you could overfill it.
  4. nateambriz
    nateambriz Member
    Lacey, WA
    70 Maverick
    Awesome thanks for the help.
  5. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Also, if you put any rubber hose in, has to be for oil.
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    When you tighten the transmission oil cooler lines be sure to put a second wrench on the welded-in fittings in the radiator to prevent them from turning. Otherwise you will probably break them out of the radiator.
