Transmisson lines?
Discussion in 'Technical' started by joshua_mcgehee, May 25, 2010.
  1. joshua_mcgehee
    joshua_mcgehee Member
    Montana
    1971 Comet
    Will mustang transmission coolant lines work for our car? I am making the swap to a automatic and rather buy prebent stuff then hassle with a bender and all that jazz.
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Pre-bent lines are available, at least for a 302 Maverick. Do a search and you should find the source.
  3. Craig Selvey
  4. Stingrayiii
    Stingrayiii Member
    Las Vegas
    1973 Ford Maverick 302/auto
    I just had to replace my lines, a belt broke and wrapped around the lines and bent them. "Don't know how that happened, but it did!".
    Only cost me about $30 for the bender and the pipe to bend. And wasn't that hard to bend into place.
    Good luck on whatever you choose.
  5. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i used mustang lins on mine. i had to rebend the angles at the transmission.
