Tremec 5 speed
Discussion in 'Technical' started by SidePipesMav5.0, Oct 9, 2005.
  1. SidePipesMav5.0
    SidePipesMav5.0 Member
    Has anybody put a tremec in a 70 maverick? If so did you have to enlarge the trans tunnel??
  2. Mavaholic
    I believe Barry had to modify his a little to get the T5 in. How much bigger is a tremec?
  3. stockhatch
    stockhatch Re Member
    Boiling Spring Lakes NC
    '72 Grabber
    The tremec is a little bit beefier than the T5, so I would imagine some massaging will be needed to get it to clear. It would still be worth the hassle though IMO.
  4. bmcdaniel
    The Tremec is wider on top because of the multiple shifter mounting locations. For the T5 I had to slit open the top of the tunnel and add some metal. Easy to do and invisible under the carpet. If the T5 gets damaged from the 347 a Tremec will be my next choice.
  5. SidePipesMav5.0
    Thanks for the replies
  6. Will
    Will I
    Waco
    74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boosted
    Just adding to what everyone else said. With a T5 your going to have to do some massaging of the tunnel and the tremec is a bit wider up top.
  7. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    we'll i might be the guine pig for tremec swap, planning to do during this winter on my mav
  8. gunslinger68
    gunslinger68 Member
    Jackson, WI
    1970 Maverick-347,tr3550,9in,etc.etc.
    I have a Tremec 3550 TKO in my car, and yes the tunnel needs to be enlarged. Not too hard to do, but the crossmember has to be made.
