Tri-Power 250
Discussion in 'Maverick/Comet Projects' started by Ken Thompson, Apr 10, 2011.
  1. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    I have been playing with a D7 250 head. I have added 3 Carter/Weber progressive carburetors. The carbs are rated at ~180cfm each or a total of 540cfm. http://my.opera.com/kat4568/albums/show.dml?id=4969252
    My next step is to add a progressive linkage, port the head, add some pieces in the ends of the intake to, to direct the air into the 1 and 6 ports. My shortblock will be a 250 crank, 300 rods and custom pistons. The cam is up in the air. The transmission will be a toploader 4 speed and the final drive ratio will be 3.25 maybe 3.55.
    My goal will be 250hps 250 loghead six.
    Any suggestions other then replacing the 6 with a V8 I'll be interested in reading.:rofl2:
    Ken
  2. maverick75
    I never knew 300 rods fit the small blocks! that's pretty neat!
    Carb setup looks great!
  3. don graham
    Looking forwar to seeing pics of the finished project. Good luck with it.:)
  4. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    maverick75, 300 rods won't fit a stock 250. The 250 rod is 5.88 c/l to c/l and a 300 rod is 6.2 c/l to c/l. the stock compression height of a 250 piston is 1.5, so I need a piston with a compression height of 1.26 to 1.28. The crank journals are the same so no machining there.
    Ken
  5. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    I look forward to seeing how it turns out.
