Trick to remove rear seat?
Discussion in 'Technical' started by gdemopesq, Jan 4, 2008.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I want to remove the rear seat bottom in my 1972 so I can trim the capret and have it fit nicely. So the rear seat is definitely going back in.
    How do I remove the rear seat bottom so I dont damage it and can re-install it? Do I have to remove the rear seat back too?
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    All you do is pop the seat frame off the front clips, kinda spring loaded. Push the seat back as hard and quick as you can, and lift a bit. It should pop out of place. You cant remove the back without removing the bottom portion first anyways.
    Dan
  3. gdemopesq
    Michigan
    72 Maverick 302
    popping it
    When I pop it, is it in an up direction or towards the front?
  4. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Dan's advice is 100% correct. The only thing I'll add is a little trick I use that makes it easier - I plant my foot on the floor against the front seat track and use my knee to push the rear bottom cushion back while lifting up. Do this on each side and it'll come out. Once you see how it's attached you'll understand why this works.
  5. don graham
    it's a back and up direction.:)
  6. mavmanerick
    royal city, washington
    yes, very easy..:)
  7. 71gold
    :hmmm: mine is a... down...back...up...all in about a 2" stroke :tiphat:
    ...:Handshake...
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Poor Frank - but the sad news doesn't belong in this thread.
    Moderator: Please move this thread to the Adult Forum.
    ( ffr :boxing:)
  9. Craig Selvey
    Yes.....I think.....I mean I KNOW Frank is correct. (My mouth now burns)
    You have to push DOWN and BACK at the same time to get it off the clips....then lift UP.
    Also...you can remove the back first before you remove the bottom. Just push down on the bottom of the seat to gain access to the two bolts that hold the back on. Take out the bolts and the rear part will lift right out. Sometimes.....it is easier to get the bottom out if you remove the BACK first.
  10. GrabA72Mav
    GrabA72Mav Living Our 2nd Childhood
    Eastern Iowa
    72 Maverick (Sold) 76 Aspen R/T Super Pack
    It's like riding a bike once you've done it its Easy!
