trim wholes are gone!
Discussion in 'Cosmetic' started by eburciaga, Aug 23, 2009.
  1. eburciaga
    eburciaga Member
    Orange County
    1974 Maverick 4 Door
    after a long day of welding and grinding they are gone
  2. mean_maverick
    nice work! great to see someone fixing a 4dr :thumbs2:
  3. 1973Maverick357
    Cookeville TN
    Looks good i need to do that to my car too!
  4. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    X2!!! looks way better :thumbs2:
  5. mean_maverick
    i dont mind the thin trim (like your's Matt), it's the LDO trim that i have a problem with...lol
  6. 1973Maverick357
    Cookeville TN
    Yeah i have that thin trim but i rather just pull it and not have to worry about.
  7. Matterick
    Lake Stevens WA
    yeah i dont mind it too much after i slam my door into those short little post at the gas station lol but besides that i dont really like it too much
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    did you do plug welds? what did you use for metal backing? all info is appreciated, and nice job..
  9. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    When I did mine, I started out using a piece of copper pipe I flattened out to put behind the holes. Without a helper to hold the copper for you it can be a bit cumbersome. After a few holes I decided it was easier to cut small squares of sheetmetal and use a welding magnet to hold them flat against the inside of the fender, then plug weld the hole from the outside. I don't mind a few little metal squares stuck to the inside of the fender. :)
  10. sierra grabber
    northern nevada
    "welding magnet" sounds like i need to buy one of those...
  11. eburciaga
    eburciaga Member
    Orange County
  12. 1973Maverick357
    Cookeville TN
    Yeah my car has an aftermarket trim.. My 71 and its missing a peice so im gonna take it all off and have fixed?? You dont even need a welder do you?
  13. Joe Dirt
    no but you need to be carefull with heat on thin panels too much makes friendly panels
  14. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    What torch did you use?
    Looks like it came out great!
  15. Mavaholic
    Thats pretty cool. I might try some of that stuff.
