Trim ?
Discussion in 'Cosmetic' started by AERDAVID, Dec 1, 2011.
  1. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    I have found plenty of seals and gaskets but where do I look (other than a JY) for trim like around rear glass, windshield ect? for my 71 Mav. I did find Head light bezels in a JY for a stagering 125.00 isn't there any AM suppliers? Thanks
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    As far as I know no one makes the trim. You need to find uses ones. I do have the trim and headlight bezel you need. Email me if you want it.
  3. Dave B
  4. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    do they actually make the "chrome" trim?
  5. Dave B
    No, but they have the correct seals and gaskets, instead of using stuff from the junkyard.
  6. Craig Selvey
    Nobody makes chrome trim for a Maverick/Comet. Got to go with used or NOS. Used ones can be sent out and plated and/or polished...or you could do it yourself.
  7. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    I was told after removing the anodizing, it could be sprayed with clear coat to keep it shinny. Any thoughts on that?
  8. Craig Selvey
    I suppose you could do that. I have never done that. I sent all my stuff out and had it polished. I am not sure if they sprayed it with clear or not. I "think" they did not.
  9. AERDAVID
    AERDAVID Member
    Florida
    1971 maverick
    No, I didn't buy the trim B&m has it, they do show a pic with the trim still on the donor and it looks good with no dents but it's still too much. The stuff I have is full of dings, I could fill and paint if I have to.
  10. Dave B
    Lots of guys here sell used parts, just post in the wanted section, and I'm sure someone will have what you want.
    The windshield trim is stainless, and can be repaired, just depends on what you want to spend, the back window trim is just easier to find replacements.
  11. XOneBadMavX76
    XOneBadMavX76 New Member
    boise
    1976 ford maverick
    i have front and rear window trim send me a pm
