Troubleshooting Heater
Discussion in 'Technical' started by Haizer, Jan 2, 2007.
  1. Haizer
    Haizer Member
    Oklahoma City, Ok
    1970 2 Door Maverick
    My heater on my 70 mav doesnt work properly, keeps blowing the fuse. I replaced the blower fan and had the blower motor tested at a shop. I also had the wiring all tested at a shop for a short but they couldnt find anything. Any ideas as to why this fuse keeps blowing out on me?
  2. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Are you using the proper fuse?
  3. 71gold
    wrap the fuse with ...tin foil..,put it back in, turn it on and where the smoke is coming from is the problem. :yup: J/K
    ...Frank...:bouncy:
  4. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    The smoke test never fails. The only thing I have learned about that is that all electrical things run on smoke. And if you let the smoke out it does not work any more.:huh:
  5. mean_maverick
    possible shorted out blower motor resistor...?
  6. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    motor
    Check your ground, then have the motor meter for resistance and shorts itself.
  7. PaulS
    If you are using the right fuse, the fuse is held tightly in the holder and there are no shorts in the wiring then the motor is the only device that can be bad. Just because it is new doesn't mean it is good. I have seen lots of bad NEW parts!
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Unplug fan motor, see if fuse blows. Then unplug resistor. same. Keep following back and feel wire for damage or pinches. Good Luck
    They do make circut breakers you may plug in the fuse or you can wire one in to find your short. Gotta watch the foil wrap, may end up with only a title.
  9. Haizer
    Haizer Member
    Oklahoma City, Ok
    Tried this actually... suprisingly it just melts the tin foil.
  10. Haizer
    Haizer Member
    Oklahoma City, Ok
    Hope this isnt it becuase i bought it over a year ago. Didnt fix it but was to lazy to mess with it anymore. Because I was lazy... damn warranty expired on the part already. :slap:
