Trying to follow instructions
Discussion in 'Technical' started by Racer_X, Apr 1, 2011.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    so last night i was installing one of those B&M shift kits in my c-4 but some of the wording in the instructions has me stumped:hmmm:. the are several smal parts that you remove to put in plugs/bearing.....ect, but it says to install the small parts that you take out to put the bearing/Plug in "as removed"(two small shaft thingies in the valve body and the plate that covers them) dose this mean i put them back in they way i took them out or does it mean i leave them out, im sure u have to put those two small shafts back in but i just want to be sure. it also says to remove the accumilator valve and do somthin with the spring thats in it. it said to take the pin out and it should push right out but it didnt so i put the pin back in and left it alone instead of trying to force it out.
    Really need some help with this:hmmm:
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Following Instructions..
    I'd suggest you call B&M Tech.Line .. They should have someone there to help. If not .. maybe someone on the forum installed the exact type of kit and could help. Wish you success.:) Cometized
  3. Bryant
    wait for pauls. he should be able to help you. you may want to post this question in the transmission section, he seems to check that first, or send him a pm
  4. PaulS
    Don't send me a PM or Email - it will be a waste of time.
    The B&M kit is junk as far as I am concerned and I would not recommend it for any C4. The last direct hands-on experience that I have had was 30+ years ago and it was junk then. From allthe complaints (from my customers and others) I believe they are still junk.
    Other than that I am sure that I can't help with any kit from B&M - other than advising you to get another valve body and install the TransGo kit in it. I have never heard anyone complain about them and I used to use them until I engineered my own mods which go just a tad (big difference) further than the TransGo kits do.
  5. dschrodt
    dschrodt Member
    Ellijay, Georgia
    1969.5 Maverick
    So, in other words, there is no help available:naughty:. Just opinions.
  6. 71gold
    ...:tiphat:...
  7. Racer_X
    North Carolina
    i will call B&Mand find out. a friend of mine has one in his C-4 and i havnt herd him complain about it at all
