Trying to get an idea of an ET for my comet
Discussion in 'Drag Racing' started by EnTeDe, May 28, 2008.
  1. EnTeDe
    EnTeDe Member
    Cedar Park, Texas
    Red and White '77 Mercury Comet GT
    77 comet in the avatar
    Motor
    302 w/ chet herbert .663 inch lift 318 @ .050" solid roller
    world product Jr aluminum heads 210 cc chambers k motion springs 1:6 rockers parker funnel web intake 750 dominator 1 5/8" hedders. 12 1/2:1 compression
    Suspension
    Ladder bar system, subframed, narrowed 8.8 5 inches on either side
    drivetrain
    463 gears, t5 transmission, 3.35 first gear, steel clutch (non diaphragm) steel flywheel,it has been tubbed and has M/T 29.5 13.5 15 ET drag radials
    MSD 7AL2 8000 rev limiter MSD pro power coil and billet distributer
    i'm shifting at 7500
    i want to have an idea of how fast the car should go before i take it in a couple of weeks. thank you for your opinions and experience.
  2. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
  3. don graham
    I would guess somewhere in the 11's. I would think you are going to be limited by the headers. Not sure about the t-5 either. What does the car weigh? Do you have a roll bar in it? I'm assuming your talking 1/4 mile?:) If the car has a full interior and is street legal it may be in the low 12's. I see your in TX. I believe most tracks there are 1/8 mile. I think that translates to the 6's but i'm still guessing.
  4. blugene
    :Welcome:
    Is Cedar Park by Gun Barrell? :hmmm:
  5. blugene
    Maybe i'm thinking about Cedar Creek...
  6. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    I would guess 6.50s is close, what size of slick will make a difference also!
  7. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    I agree with Mr. Graham, sorry I meant Don.
    Headers are going to slow you down.
    Lot of questions to answer before I could say.
    Rule of thumb for every 1 pound of rotion weight you remove it's the same as 10 pounds of dead weight, so what front wheels and tires are you running?
    Have you removed anything inside the car? Was this a car with AC?
    Does the car still have the sway bar on it?
    Bossmav
  8. EnTeDe
    EnTeDe Member
    Cedar Park, Texas
    i have centerline 15x5's in the front, the car weighs 3000 lbs it has an 8pt roll cage. the slicks are 29.5 13.5's on centerline 15's. it has been tubbed so it has no back seats and it has no rear sheet metal in the trunk because it has been subframed. it has recaro buckets in the front it still has the sway bar.it will pick the front tires up on the street if that helps any. i am running 1/4 mile
  9. EnTeDe
    EnTeDe Member
    Cedar Park, Texas
    it's connected to north austin. i run the car in little river and at san antonio raceway
  10. blugene
    Oh yea... I remember now. I used to work at the Pep Boys there on 183 (Research), just south of you.
    Glad you found us and get some pics of the air gap. Or some video, we love that kinda stuff. :yup:
    Sorry to jump off your question without an answer...
  11. valleyracer
    valleyracer Member
    Ottawa Canada
    10.80 to 11.20?
  12. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    First time out? How much experience do you have with the T5? I'm thinking mid to low 11's at first, but with that suspension and tire I would expect it to have mid 10's potential. Not to rag on you, but most people when they first start ringing out a car it takes a while to get the feel for it. That's why I thought it would start with mid 11's.
  13. EnTeDe
    EnTeDe Member
    Cedar Park, Texas
    yeah, i got about a years worth of experience on a street mustang (04) that had a t5 in it which ran 13.20's. the t5 in the comet now has 80,000 miles and hardened gears so the shift pattern is pretty well set in. also, before we put the heads and cam in the comet i drove it to school daily so hopefully i'll be able to pull out a 10.99 by the end of the night.
  14. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Sounds like you are on your way! I've seen so many guys at the drag strip that just don't know how to shift a manual at the track. Good luck and let us know how you do!
  15. don graham
    I'm thinking 3000 pounds is going to hurt that time also. Let us know what happens. Good luck, but I don't believe your going to see 10's with that weight. But I was wrong once before.:biglaugh:
