Tuning a Holley.
Discussion in 'Technical' started by Country Mav, Sep 10, 2005.
  1. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Hey guys and gals, just swapped my Edelbrock out for a Holley Carb. Now I need a little help.I can't find any exploded views or diagrams of a Holley showing which screws are for mixture, and which is for idle. It will crank and run, just not well.:rolleyes: When I get it to idle good in park, putting it in gear pulls it down too far. It spits and stutters when I drive it, BUT it already makes more power than it did with the Edelbrock. So can anybody offer any advice here? New to Holleys. Thanks! Preston
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Stop what you are doing, right now!
    Go buy a book on tuning Holleys.
    They usually run under 20 bux, best 20 bux you'll ever spend.
    Get the book that focuses primarily on your model carb and goes deep into performance tuning.
    The areas you will need to work on right away:
    Adjusting pump linkage
    Setting idle mix (the screw on each side of the primary block)
    Setting idle speed
    Checking float level (get clear sight plugs for this, much easier)
    Vacuum port in the primary block goes to distributor
    Any in the base are for things like pcv, power brakes, modulator valve
    Speaking of auto trannys... add a Ford style kickdown if your carb doesn't have one.
    Get reusable bowl/block gaskets in there fairly quick. If you wait, then jet fine tuning later will be a pain with the factory gaskets baked on. The jets should be safe for running now.
    Don't do major changes from your baseline, such as jets, squirters, and such, until you have it running fair. Do changes from there ONE AT A TIME! Multiple changes at once can lead to problems. One change might cancel another and you will never know it, or worse yet, one change can cause an issue but you made several, so you have to guess which change caused the issue.
    Let us know more!
    What model (list) number did you get?
    What CFM?
    Vacuum or DP?
    Single or double fuel line?
    New or used?
    If used, has it been gone through?
    What tranny?
    What gears?
    What intake?
    What cam?
    Dave
    Btw: Isn't it amazing how you can feel the difference?
    I noticed with several carbs, that I swapped to a Holley, how much better the car ran. Holleys are not known for economy, but they perform better than anything out there.
  3. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    One more reason I love my AFB, no tinkering.........I bought 2 new Holley carbs and both of them poured gas out of the top of them when I put them on. I've never had any problems with Carters or Edelbrocks, but I'm not a serious racer either.
  4. ratio411
    ratio411 Member
    Pensacola
    Float level too high or too much fuel pump pressure. Easy fix.
    Holleys do require a bit a time and thought to set up, but after that you are gold for a long time. The car runs so much better because of the tunability of a Holley.
  5. Country Mav
    Evans, Louisiana
    Yep, that's why I hated my Edelbrock. It ran like crap and you COULDN'T tune it. Not much anyway. Like I say, I just sat it on there, and took it for a test drive. Not running good at all, and STILL made more power than with the Edelbrock on the rare occasion that it ran decent. I'll have to check on the model numbers. I traded with a friend of mine. This was a spare carb of his, he's going to give the Edelbrock to another guy. It is used, but he had it on a 289 and on a 302 and it ran well on both. It's just that he lives 80 miles from here, so he can't just hop over here and tune it. :D I believe I will get a book on it, just gotta get the model number. It's on top, isn't it? Thanks guys! Preston
  6. ratio411
    ratio411 Member
    Pensacola
    It's on the front of the air horn.
    It will say "LIST XXXX-X"
    An example would be "LIST 3310-3"
    That would be a 750 vacuum, 3rd generation...
    If the carb was on other SBFs, it might be tuned really close unless his engines were more radical or the carb has set longer than say 6 months. Either case would require some work.
    Dave
  7. Country Mav
    Evans, Louisiana
    Thanks Mr. Dave! (y) I appreciate it. Preston
  8. fastmav302
    fastmav302 Member
    olive branch,ms
    1973 maverick
    im only 15 years old, but i have learned a lot. i would run the vacuum hose form the dist. to the nipple on the front of the carb on the bottom and cover up the one on the metering block. i think that it pulls better vacuum that way. also the idle screw are on the side of the metering block. turn both of the screws in all ythe way then bring it back out about 1.5 turns then fine tune. to make sure that your floats are not set too high take the screw out of the side of the bowls. if the gas pours out the floats are too high. the gas should barely come out. that should help out. it helped me when i had that problem.
  9. ratio411
    ratio411 Member
    Pensacola
    Can't do that...
    The bottom vacuum port pulls more, but the distributor needs less to function properly.
    Better explained, the port above the throttle plate pulls little vac at idle, but more as the throttle plates open. That is when you want your advance to come in. The ports in the plate are exactly opposite. They pull more at idle, but less as the plates open... so you are not getting your timing when you mash the gas.
    The port on the block is MADE for the distributor function, don't try to re-invent the wheel.
    If you are advancing the timing at idle, then set it properly, your timing is actually retarding as you accellerate the way you are currently operating.
    Dave
  10. fastmav302
    fastmav302 Member
    olive branch,ms
    1973 maverick
    i guess i learn something new everyday
  11. Scotty P
    Scotty P Member
    santa rosa, ca
    And THAT is my daily goal!:clap:
  12. ratio411
    ratio411 Member
    Pensacola
    Olive Branch eh...
    The Mav in my avitar is a Memphis native.
    Picked it up while living around Hickory Hill.
    I want to say it was from a Ford lot in Olive Branch... but I can't remember for sure. I pulled the dealer chrome off years ago.
  13. 77mav302
    77mav302 Member
    Spokane WA.
    77mav302/2dr, 70mav 2dr
    hey Country, check this site out, READ it thoroughly though. if you have questions most can be answered by just reading further.
    http://www.bob2000.com/carb.htm
  14. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    wow...good post! Very good read!
  15. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Seems like a very good page to help out
