turbo parts list?
Discussion in 'Drag Racing' started by pil1sbury, Feb 7, 2015.
  1. pil1sbury
    pil1sbury MavBoy living life
    Virginia
    1974 FORD MAVERICK
    I already made a post "its turboing time" asking about why type of turbo I should get. So now I'm trying to make a list of what I need to get.
    I have some stuff written down at home but nobody remembers everything so help me out please!!!(y):character0182:
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Turbo, wastegate, blow off valve, oil feed and return line, exhaust tubing, cold side tubing, intercooler, boost timing master, wide band o2 sensor, blow thru carb (if going carb), fuel pump, boost referenced fuel pressure regulator, boost gauge, boost check valve for vacuum modulator if auto trans. I'm probably forgetting something, I'll add to this list later if I remember. I hope you have some sort of locking diff, otherwise you're gonna go through a lot of right rear tires. Another thing I found necessary is an electric cooling fan, and if your trans is original I'd recommend a rebuild with a shift kit and upgraded converter at the very least.
    Nakase likes this.
  3. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Turbo
    turbo manifold
    biggest downpipe you can squeeze down car
    tial or turbo smart wastegate
    tial or turbosmart bov
    blow through carb, CSU
    Carb hat extreme velocity
    filter for turbo
    Cold side plumbing and silicone couplers
    possible intercoodepending on boost and or if using reg gas and not e85
    turbo feed line 3 or 4an..depends on turbo
    turbo drain line 10an
    bung welded to oil pan
    Electric fuel pump....better yet fuel module
    pump voltage regulator dependending o. Pump....aeromotive
    fuel pressure regulator boost referenced...can get electronic control fuelab if going with their pump or fuel module
    fuel filter pre and post
    msd 6 2al programable ignition box
    magnetic pickup distributor
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
