Turn signal issues!
Discussion in 'Technical' started by ccheeks14, Mar 21, 2012.
  1. ccheeks14
    ccheeks14 Member
    Portland, OR
    1976 Maverick
    I have a 76. Neither of my front side signals work, and my left signals flash reallyyyyy slowly and sometimes don't make the noise. But the right side seems to work fine. I checked all the bulbs and replaced the flasher, any idea what's wrong?
  2. Craig Selvey
    Sounds like it could be:
    1. Grounds. Check your grounds on the front wiring harness and on the front turn signals.
    2. Turn signal switch. Could be the switch is bad.
  3. ccheeks14
    ccheeks14 Member
    Portland, OR
    1976 Maverick
    Ill check both of those out, thanks!
