Turning signal help
Discussion in 'Technical' started by Chenny94, Jan 11, 2014.
  1. Chenny94
    Chenny94 Member
    1974 Maverick
    I replace one flasher. I heard there was another one. Is there? It's not working and it's starting to tick me off. Haha. Could anyone give me any advice?
  2. MichAnJD
    MichAnJD Member
    california
    1971 maverick grabber
    check if its getting power when the ignition is on.
    the hazard relay has a power all the time.
    check it with a light tester.
  3. Chenny94
    Chenny94 Member
    1974 Maverick
    how would i do that? Step by step please? Haha.
  4. Rasit
    Rasit Member
    SE Pennsylvania
    There are two flashers...a hazard flasher and a directional flasher.
  5. MichAnJD
    MichAnJD Member
    california
    ground your light tester to chasis and stick the tester to the plug where the flasher relay hook up dont take it off just stick it in there theres two flasher relay there the other one should light up the light tester thats for your hazard then the other you need to turn the ignition to on position then the other flasher relay should get power.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    You probably replaced the Hazard flasher. The turn signal flasher is often located under the dash, above the parking brake handle.
