Two ?'s Where tp buy sub-frame connectors and a cheap center link?
Discussion in 'Technical' started by rsillmon, Sep 5, 2009.
  1. rsillmon
    rsillmon Sneaky Snake
    Caroline,VA
    Maverick
    I have a 70' maverick with manual steering and need to replace my center link or rebuild it if possible. The cheapest I found was at PST for $188.00 and would rebuild my old one, if I knew if anyone sells the rebuild kit. My next question is that I need to get some sub-frame connectors and can not find any for sell? Thanks for any infor:)
  2. PaulS
    Sub frame connectors can be made with a hack-saw and welder if you can work them and take some basic measurements under the car.
    I built mine (for my Muskrat) for $45 worth of steel and some time.
  3. Bryant
    isnt the center link basicly a bar with holes in it?
    it may have a ball joint on the end that goes to the pitman arm, but i cant rember. i dont think you should need to rebuild or replace it.
  4. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Dan Starnes had fabbed some sub-frame connectors to sell.
    Do a search here for his name/username. He is club secretary for the Maverick Comet Club International(MCCI).
  5. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    Rudy Bidlack makes and sells them.....someone here can tell you his screen name but he advertised in the back of shorthorns.
    Robert
  6. rsillmon
    Caroline,VA
    Maverick
    Found frame connectors
    :thumbs2:I did find a place that sells subframe connectors for $99.00, which I already place an order from Chassis engineering. Still looking for a cheap center link or a way to rebuild the old one. Thanks Robert
  7. rsillmon
    Caroline,VA
    Maverick
    Yes, my stud on the center link is wore out, I like what you said about it being just a regular ball joint, so maybe I can just press out the joint and then I need to know what ball joint will fit in place of the old one? I see some companys will take your old center link as a core and rebuild to resell for over $200.00, thats just too much. So, that means they can be rebuilt. Any ideas what ball joint to use? Thanks Robert(y)
  8. Bryant
    i have no idea as to what ball joint can be used.
  9. rsillmon
    Caroline,VA
    Maverick
    I might have it figured out!!
    I'am here looking over my new front end parts and notice that the outer and inner tie rods have that same type of ball joint pressed on them, the outer joint is too small. but the inner tie rod looks the same as the drag link joint. I will press out the old ones and compare them, if they are the same I will just buy an extra inner tie rod and have the joint pressed out and put on my drag link.(y) Hope for the best and maybe save alot of money.
  10. mean_maverick
    if all else fails, i have a manual steering setup for sale. just lemme know if interested :)
  11. baddad457
    You can buy a new centerlink thru Autozone.com. "Rare Parts" is the vendor.
  12. rsillmon
    Caroline,VA
    Maverick
    Is it new and how much?
  13. rsillmon
    Caroline,VA
    Maverick
    Thanks, I will check them out.:yahoo:
  14. baddad457
    Advance Auto Parts also offers the same parts from Rare Parts, but when I did mine two years ago, there prices were double Autozone's. Might want to check em out though just in case things changed.
