Typical size pipe for 300 hp engine
Discussion in 'Technical' started by Slk70, Apr 25, 2007.
  1. Slk70
    Slk70 Member
    Los Angeles
    Opened box and just found out the Hooker 6901's do not come with reducers. Why... not sure, not too happy about that. Anyway, I have a maybe 300+ HP 302. Wanted to know what size pipe to run which will also end up being the size reducer I buy. I will not buy from Hooker though.
    A rep told they started selling them seperatley to of course "make a few extra bucks". What makes them think people will buy theirs though? What seems typical on the pipe size for this motor. No stall or track car. Just street only.
    Also, does anyone know of a good inexpensive reducer that mates well with their headers.
  2. stmanser
    Davenport, Iowa
    i used 2 1/4 exhaust all the way out.. with dual flowmaster 40 series mufflers
    it sounds bad ass if i say so myself.. well.. here.. listen for yourself
  3. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Are you spinning on rocks?
  4. stmanser
    Davenport, Iowa
    yeah the road was a little rocky.. it was the only thing i could find without being on a major road.. we brushed some of them away with our feet..
    and no.. that is not why i was able to break traction.. it was all motor.. :)
  5. 71gold
    300 RWHP or 300 FWHP?
    ...and what size reducer were you expecting with your headers? you are asking "what size pipe to run"? so Hooker (and any place else) will need the same info to get you the right reducer...:huh: JMO
    ...:bouncy:...
  6. bmcdaniel
    Not everyone who buys headers uses reducers. My next time around I'm considering using 3" diameter collector extensions that taper down to 2 1/2" at about 20" length.
  7. Slk70
    Slk70 Member
    Los Angeles
    71gold. I am not sure, that's why I was asking on the pipe size. I looked on Summit yesterday and you need to know what pipe to get the right reducer.
  8. stmanser
    Davenport, Iowa
    you cant go wrong with 2 1/4 or 2 1/2 pipe.. you could go 3" but you better have the intake and engine to support it
  9. j miller
    Polson, Mt
    i had 2 1/2 coming off of the header to the muffler then reduced again to 2" to get over the axle. i had to take it off due to the fact that the 2" bend was chokeing the life out of my engine. i would suggest 2 1/2 all the way but it is a real pain to get them out the rear past the gas tank. i went with 3" glasspacks attached to the collector and i love it. very loud tho.
  10. bmcdaniel
    His 70 Mav doesn't have the problem with the gas tank sender on the side. 2 1/4" would be fine for your combo, 2 1/2" wouldn't hurt. I wouldn't go any bigger.
  11. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    3-inch is Bull#### for a 300hp engine, unless you simply like the noise...
  12. 71gold
    my reply was to this question...:yup:
    ...:bouncy: ...
  13. j miller
    Polson, Mt
    if he doesn't have the sender then i would stick with 2 1/2 ". that way if he ever added h.p. he would already be set up for it.
    T.L.-- thanks for sharing your opinion. unless you have seen a my set up and helped me tune it in person then your opinion as to my choices doesn't really matter. i am running 365 fwhp and needed the extra breathing room. not all engines run exactly alike.
    and yes i (and everyone who crowds around it at the shows) like the "noise" it makes.
  14. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    ive got 3.5 inch collector extenison and sounds good :yup: when its running:(
    2.5 should be just fine:thumbs2:
  15. scooper77515
    My muffler guy said that 3" would be too much, and put on 2-1/2" all the way with a reducer right after my dumps. 24" glasspacks. I had them out the side in front of the rear wheels, but had to cut them off to put on caltracs, and now will downturn them just after the glasspacks.
    Legal here...luckily.
