U shaped tube on header
Discussion in 'General Maverick/Comet' started by smegnl, Dec 26, 2019.
  1. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    What is this thing for ?
  2. Hotrock
    Munroe Falls, Ohio
    That is a heat tube for carburetors that have a heat stove to open and close the choke. A metallic tube is connected from the header heat tube to the carburetor heat stove on the choke.
    Krazy Comet likes this.
  3. Krazy Comet
    Fairlanemilagechoke 018.JPG I recently connected the hot air choke on my Fairlane. It has a addon plate that suppliese hot air, no fresh air supply.
    For the tubing I swiped a balance tube from a T-Bird steering rack & pinion(connects between R & L boots).
    For better efficiency, factory covered tubing with fiberglass(or maybe asbestos :nailbiting:) to reduce heat loss. I used a old oven door gasket on mine.
  4. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    got it, that makes perfect sense.
