UCA differences
Discussion in 'Technical' started by Racer_X, Jun 25, 2013.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    are there any major differences between 65-66 mustang upper control arms and maverick upper control arms, back when I replaced my uca's I ended up using the 65-66 uca's, compared to my old ones they looked exactly the same. Ive also been reading that 67-68 are the ones that are the direct fit on a mav.
  2. Mavman72
    67/68 are direct replacements for a mav...And...You can get em with 4 bolt ball joints as opposed to the typical 3 bolt joint common to mavs'.Not a big deal but...
    Havent personally used the 65/66 ones though. Cant see there being a real difference, and since you have allready used em with success, I would imagine there isnt a difference.
  3. John Holden
    John Holden Member
    NJ
    The bolts on the shafts are spaced different on the 65-66 mustangs.
  4. rthomas771
    Bolts are longer also for the alignment shims
