Uh oh...found something bad in my oil pan. What "was" this?
Discussion in 'General Maverick/Comet' started by scooper77515, Apr 25, 2013.
  1. scooper77515
    Replacing oilpan before dropping engine onto the new and I found these at the bottom.
    What was this?
    Engine has been running fine. But this still does not look good.
  2. rthomas771
    Valve Keeper aka Lock. It keeps the valve from falling into the cylinder
  3. scooper77515
    So, this is where those two halves of valve locks snap into, to provide pressure to keep the valve up?
    Can this be replaced?
    I mean, can I order one and pull the head and replace the missing one?
    Or do I need an entire new head?
  4. scooper77515
    Well, I have identified that it is on cylinder #4...
    How bad is the piston going to look?
    As I said, it ran fine the last time I drove it. Might have been missing a little, but nothing that sounded serious that would have gotten me suspicious.
  5. Ryan
    Ryan Ford Addict
    Phoenix Az.
    never seen a valve keeper with holes in it like that. My first thought was the collar on the distributor to keep the shaft from pulling out and the roll pin goes through it.
  6. Ryan
    Ryan Ford Addict
    Phoenix Az.
    That could be normal wear from the up and down movement. some valves will be lower then others depending on cam postion at the moment.
  7. scooper77515
    What would have caused this to break?
  8. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Was it ever a whole solid circle or is it machined as 2 pieces?
  9. scooper77515
    I have another distributor gear and it does look alot like that, and same size.
    It was solid, and has broken at the holes.
  10. Ryan
    Ryan Ford Addict
    Phoenix Az.
    did you pull the one out of the engine?
    Not a valve keeper if it was solid. Pull up the distributor and see if there is a collar on the shaft where it meets the body.
  11. scooper77515
    Good call! :clap:
  12. scooper77515
    Again, what would cause THIS to break?
  13. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Weird that it broke. did you ever have a hard time getting dist in or out and had to use a hammer or pry bar?
  14. scooper77515
    None of the above. :hmmm:
  15. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Just one of those things i bet. if you wouldnt have pulled the pan youd probably still be running like that. Dont see it hurting anything.
