UK Maverick
Discussion in 'General Maverick/Comet' started by TheTransplanter, Jun 20, 2018.
  1. TheTransplanter
    TheTransplanter Member
    England
    73 Mav & 65 Cyclone
    Hi all
    As the title suggests im in the UK and own a 1973 250 Auto LDO in Medium Green with a dark green halo vinyl roof.
    I bought this as a stop gap whilst I restrore my 65 Cyclone, but I have found myself wanting to do more and more to the Maverick :D
    I imported the car from NorCal a couple of months back and have now registered it in the UK. Just now im going through the mechanical's as it has not been tagged since 2013 so it needed going through.
    I fitted a new brake master cylinder and have done around 100 miles in it, but it overheats on faster roads. I have removed the thermostat and flushed the cooling system which has made it better but its still not as it should be, so have ordered a new radiator, thermostat, water pump & head gasket from Rockauto, so am currently waiting for those parts to turn up.
    Whilst im waiting I have decided that I hate the medium green and much prefer the medium lime green :hungry: So I have ordered some 1970 Grabber side decals & a 1973 hood decals. So the plan is now to get it into my shop and prep it for a color change and remove the ldo side trim and weld up the holes.
    So I will update the thread once work starts (just need to finish of a VW first),
    Also my friend in NorCal is looking out for a 5.0 roller motor for me at the moment, so will has some V8 swap questions in the near future o_O
    Pics of the Maverick as I purchased it in my garage :tiphat:
    More soon
    Cheers
    Al
  2. tody
    tody Member
    cologne, germany
    Welcome from Germany! There are a few fellow UK members on here, I'm sure they'll chime in soon. And post some pictures of your car!
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hello Al :
    Noticed your post on the overheating problems. You've done everything right so far and I think your car would
    benefit from a nice fitting Fan Shroud . It makes quite a difference in the cooling. Hope your new car is a joy to
    you.
    Cometized
    (Chip)
  4. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    Overheating is generally not solved by removing the thermostat, in fact, its absence can cause overheating. Recommend you refit one when you do the water pump. Also, how full are you filling the radiator? This vintage Ford radiator uses the top of the tank as the expansion chamber. The "full" level of a fully bled, cold cooling system should only be a little more than 1/4-inch above the core as visible through the filler. If you fill it to the top of the filler neck, as you would on a modern car, the coolant will expand when it warms up and be forced out of the overflow.
    Hotrock likes this.
  5. TheTransplanter
    England
    73 Mav & 65 Cyclone
    Thanks for the advise. The stat was only taken out for experimental purposes to see if it was stuck. Im a mechanic of over 35 years so have a healthy mechanical knowledge, just very little on these Ford sixes or Mavericks and their quirks.
    Im still waiting for parts to turn up from Rock auto so not much to report on the overheating, but I have just scored a 5.0 HO Roller motor with the AOD with only 40k miles on it so that will be shipped to me in in good time, so will be looking for parts to make that happen in the near future.
    In the mean time im going to get it into my workshop for a re-paint
    William623 likes this.
  6. TheTransplanter
    England
    73 Mav & 65 Cyclone
    Since the day I bought the Maverick I knew the had to be tucked.
    So moved it back 2 1/4 "
    Looks less like a breakfast bar now! IMG_4875.JPG IMG_4876.JPG IMG_4877.JPG IMG_4875.JPG IMG_4876.JPG
  7. Earl Branham
    Lugoff, SC
    Welcome, from S.C., USA!
  8. TheTransplanter
    England
    73 Mav & 65 Cyclone
    Spent yesterday stripping all the bright work off, and welded up the 38 LDO side trim holes :90: IMG_4892.JPG IMG_4894.JPG IMG_4895.JPG
    CA189HJN likes this.
  9. CaptainComet
    Nice job on the bumper tuck. I also like the dog dish hubcap swap. Guessing those came from your '65? I have gotten stupid money for those Mercury caps on eBay. Rat rod guys love 'em.
  10. TheTransplanter
    England
    73 Mav & 65 Cyclone
    Yes the dog dishes were borrowed from my 65 although not original to the Cyclone! I have some 15" TT's to go on the Maverick once its painted :)
    Im looking at tucking the rear bumper as well on the 73, although its a small bumper it must stick out a further 1.5". I have already removed the lower corner parts and welded up the holes, I just need to rework the bumper brackets to get it like the earlier models.
    But im concentrating on the repaint for now. Well I changed my mind on the Lime green metallic, and opted for......... LOL
  11. TheTransplanter
    England
    73 Mav & 65 Cyclone
  12. TheTransplanter
    England
    73 Mav & 65 Cyclone
    The paintwork is now done, and the vinyl roof dyed black (from green), and I have now fitted back up together. Waiting on a few bits and pieces from Melvins, but its now driveable again :)
    IMG_5046.JPG IMG_5046.JPG IMG_5045.JPG IMG_5047.JPG IMG_5048.JPG IMG_5049.JPG
    I still have the side grabber decals to fit but im waiting for the weather to cool down a bit as we are currently having a heatwave here in the UK lol (happens about once every 40 years).
    I also cut down the rear bumper brackets by 1" to tuck it in, but the bumper needs to go up about 1 1/4" as well! So I need to remove the bumper and rework the brackets again
    mojo and CaptainComet like this.
  13. CaptainComet
    I admire the speed in which you have made all this progress on the car. Nice job.
    On the 70-72 Mavericks, there is a small filler piece that helps visually take up that gap between the rear fender caps and the bumper. It looks a bit like a tiny outboard boat motor. I think the rear bumper may only need to be picked up about half as much as you are currently thinking.
    This is the rear of mine. It almost has decent panel gaps and fitment .... :(
  14. CaptainComet
  15. tody
    tody Member
    cologne, germany
    wow, what a difference a little paint makes...
    TheTransplanter likes this.
