Under the hood upgrades
Discussion in 'Technical' started by 72cometdlx, Jun 7, 2002.
  1. 72cometdlx
    72cometdlx New Member
    va
    comet
    I saw a ford 302 gt40 engine that I was thinking about putting in my 72 comet and I want to get a strong manual tranny also, but I do not know what all this process intails. Anybody know what I need to do.
  2. K. Merring
    K. Merring Regular
    Easton,Pa.
    73 Comet GT
    Assuming you already have a 302 in place, you will need a late top loader trans and a clutch operation setup. The trans mount may have to be fabbed as an addon to the existing crossmember.
    The drive shaft may have to have a length change. The pully setup on the engine may need some changes depending on which way you want to go with the belts and accessories.
    If you have to replace a 6 cylinder, then thing get more complicated. You now will need motor mounts, a V8 radiator, a new exhaust system and a number of small items in addition , if the car has an auto trans., you will need a clutch pedal assembly from a standard shift Mav.
    This is an overview, so a peticular project will have its own set of conditions to be worked out.
