underhood wiring-auto trans
Discussion in 'New Members Forum' started by bandit63, Jul 9, 2006.
  1. bandit63
    bandit63 New Member
    Menifee Calif.
    1974 maverick 2DR
    does anybody have or make new wiring for under hood? I'm installing a 302 in my 74 had a 250 before.I would like the wiring loom that goes to the coil,temp and oil press. My C4 that was with the 250 only has one vacuum line, the trans on the 302 has two vacuums(1973)Can I put the two vacuum line modulator on my 74 trans. I don't know the cond. of the 73 trans. thats why I would like to change the mod.and the two lines come up at the bell housing, makes for a cleaner setup.Thanks Lee
  2. Jamie Miles
    Alto, GA
    I've had a few
    :Welcome:
    How does 2 lines make for a cleaner setup? Most people swap the 2 line modulators out for the one line modulators.
  3. Mavaholic
    Howdy and :Welcome:
    Nobody makes wiring harnesses for our cars.
  4. maverick75
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    You'll need to get a V8 sensor harness or splice the one you have to make them longer. They do reproduce Mustangs Sensor harnesses ... I'd be curious to see if the connector is the same and if it would work on a Maverick.
    Just swap modulators and use the current vacuum setup.
  6. bandit63
    bandit63 New Member
    Menifee Calif.
    1974 maverick 2DR
    Thanks for the input, I'll come up with something. the reason I wanted to use the two vacuum lines.They are still attached to the trans and come up very nice at the bellhousing. The one on my car is like a dogs leg and it went to the intake of my old six.
