Unknown Battery Drain?!! HELP?!!
Discussion in 'General Maverick/Comet' started by Jony, Aug 29, 2018.
  1. Jony
    Jony Banned
    1972 Ford Maverick Grabber 5.0L 302 v8 NA
    Hello everyone, haven’t been on here for a while now but I need help from anyone at this point! As said in the title I have an unknown battery drain in my maverick. I’ve replaced most of the ignition except for the distributor and spark plug cables. Yet I still have a HUGE drain. I also have an aftermarket radio install that I will be taking out and checking on it. If it’s not that, what else could it be? Thoughts?
  2. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    Have you tried removing fusses, unplugging wires to isolate the drain?
    jasonwthompson likes this.
  3. Krazy Comet
    Replacing parts is no way to troubleshoot. Just wastes time and cost money.
    Connect a test light with conventional light bulb(none of this modern LED stuff) between negative cable and battery post(first remove cable from batt). With a drain of ¼ amp or more it should light brightly. Next remove various fuses and disconnect electrical items. When light goes out, problem found.
    Miguel Arzola and BBMS18 like this.
  4. Hotrock
    Munroe Falls, Ohio
    Just a guess that it probably is your aftermarket radio as it may require a current to maintain station settings. Mine does that, so the solution is to disconnect the negative battery cable when the car is not in operation for an extended period (downside is you have to reset radio stations each time you drive the car) or get a Battery Tender. I have a Battery Tender Jr that works just fine.
  5. airford1
    airford1 Member
    San Dimas, Ca
    Place a volt meter on your battery and start pulling fuses.
  6. JL Mav
    JL Mav I almost made it to Lake Tahoe
    Douglas county NV
    72 Maverick, 68 Mustang, 61 F100 unibody
    If it is a large drain. disconnect the battery then the alternator, making sure that you keep the main wire from grounding then reconnect the battery, if the drain goes away then it is a shorted diode in the alternator. This short will drain a battery a fast as leaving the headlights on. Good luck.
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    I experienced a drain on one of the cars inside the shop and discovered the ALARM on the car was draining a significant amount of power . Just a thought.
    Cometized
    (Chip)
