Unknown Gasoline Leak
Discussion in 'General Maverick/Comet' started by Jony, Jan 26, 2016.
  1. Jony
    Jony Banned
    1972 Ford Maverick Grabber 5.0L 302 v8 NA
    Hey guys, I need help with this problem that I have! My maverick is a '72 Grabber 302 and the fuel filter is located near the distributor and the carburetor (that's how it was when I first bought it). I noticed that around there was a small puddle of gas on the intake manifold! I am not sure what to do because every time I check the filter, it is never dripping in gasoline. I also need to mention the the carburetor installed was an aftermarket Weiand and I am hoping that it is not coming from there! Some please let me know what I should do or check please!!
    PS- I don't know how many gallons the tank it or how many miles I get per gallon but I usually have to refill the tank 4-5 after a full tank and I use it everyday and drive about 40 minutes a day to and from my destination(s). I also need help with this!
  2. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Have you checked the where the fuel line connects to the carburetor?
  3. Jony
    Jony Banned
    Yes and not only is it still intact but there are no signs of wear which is why I need help! I wil post pictures later, more likely tomorrow because it is night but other than that I am stuck! It still runs though!
  4. 71gold
    what filter do you have?
  5. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    what kind of carb do you have? if holley, check to make sure its not the carb plate seal. or bowl seals...
  6. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    I would check it right after driving it with the engine running. Maybe it needs fuel pressure before it leaks.
  7. Jony
    Jony Banned
    I don't know what kind of filter I have but I am guessing that it is just a standard one nothing special! The carburetor is made by Weiand and I might just check the seals just in case! I have tried testing the car as it idled and there were still no signs of leaks and such. The fuel pressure is consistent as well! I could be the seals because when I first bought it off the seller he tpold me what he'd change and never mentioned anything of the seals!
  8. 71gold
    how about some pics in general of the engine?
  9. Jony
    Jony Banned
    The last one is where the gas leak usually ends up at!
  10. mojo
    I had one of those plastic filters on my car for abt 2 yrs. it almost caught the car of fire. The plastic nipples deformed, spraying fuel all over the engine compartment. I was lucky, the car started loosing power coming over a bridge one nite from a cruise-inn and abruptly stalled. I was about half mile from home, had the car towed home. I wud una$$ that "PLASTIC" POS filter first and see if you still have the leak. You've looked over most everything else and have not found the problem..
  11. Jony
    Jony Banned
    Yeah I have the same problem you had just coming out of the drive way! I will change it but which one would I buy and what brand?!
  12. 71_Maverick
    71_Maverick Member
    michigan
    I agree with mojo. I've had one of those leak before, switched to the spectre clear replacable filter.
  13. mojo
    If ur going w/ clear unit, something in the glass type segment will probably best bet. I believe the one 71_Maverick is on that order. I am using a metal filter but, also have a glass unit hanging on the garage wall. I feel better using metal, but, wud never use a plastic again; I was fortunate when my plastic unit went south. Funny thing, I had both of the filters I mentioned previously in my possession for over a year and to busy/lazy, going to get to it philosophy and it almost cost me, big time.
  14. Hotrock
    Munroe Falls, Ohio
    NCFatBoy likes this.
  15. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    IF yours is puddling near the coil, all it will take is a loose spark to ignite a underhood fire! I have been there. Check to see if the Carb is leaking at the base gasket. Check the main butterfly shaft for leaks,on sides.
