Unknown wire? Pics inside!
Discussion in 'Technical' started by keithbartley, Nov 8, 2009.
  1. keithbartley
    keithbartley New Member
    Vancouver, WA
    1977 Ford Maverick. 250 CID
    I have a wire coming off the alternator cable. It's black (with a connector in the middle?) and has a small metal connection on the end. Ignition switch? Regardless I don't want to turn on the Mav without this in!
  2. Jeff S
    Jeff S Member
    NoVA
    none
    Where is connected to on the alternator?
  3. keithbartley
    Vancouver, WA
    On the first picture on the base of the alternator you can see the wire coming out of the main cable wrap.
    I just have no clue were it connects too, I took it out to test the alternator and I think I disconnected this poor guy when I pulled on the cable. :rofl2:
  4. Jeff S
    Jeff S Member
    NoVA
    none
    Hope this gives you an idea...looks like it goes to the regulator, but dont take that as true, someone may have replaced it with a different color wire
    Id check all 5 places that the wires runs to above, theres bound to be one place missing a wire to the alternator.
  5. spork1o1
    spork1o1 Member
    Michigan
    electric choke would be my guess
  6. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I second that...I can bet it is for an electric choke...
  7. rthomas771
  8. keithbartley
    Vancouver, WA
    Only problem is I can't see were it would go, I check the wiring and everything that should be there IS there..
    On the other hand it doesn't look like I have an electric choke. No connector.
  9. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Just a guess...but I think that it's an electrical wire... :biglaugh:
