Update on Oil Leak on my '74 Comet
Discussion in 'Technical' started by Jim1970, May 29, 2006.
  1. Jim1970
    Jim1970 Member
    Wyoming
    1974 Mercury Comet
    Just a quick note following up on my newly discovered oil leak.
    (I hope this is the right place for this discussion -- I promised Ray I wouldn't put my info in the wrong place anymore!!).
    Just out of curiosity, I put a 7/8" ratchet on each of the bolts -- and every single one of them was loose enough I could turn them without the socket wrench, just using the extension and the socket!! So, I snugged them down on a cold motor and was careful. Let's see if she leaks now!!
    Thanks for the gasket ideas. After tightening the bolts, I'm sure I could repalce the gasket if needed.
    Jim
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Glad that's all it took....
  3. 71gold
    (y) :Handshake
    ...frank...:bouncy:
  4. blugene
    Not trying to be smart here but... a ratchet is what the socket or extension(two of many) goes onto and 7/8? That is kinda overkill for valve covers.:biglaugh: Might get rid of them foreign tools and get you some snap on':p
  5. don graham
    probably meant 7/16. glad that's all it was. most of the work on the mavericks is pretty straightforward. if you plan on doing any other work on it you might see about getting a chiltons manual.:)
