Upper control arm bushings
Discussion in 'Technical' started by Slantsickness, May 23, 2007.
  1. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    Alright, just got my frontend kit from PST. Was going to take the control arms in to work tommorow to change out the bushings. Problem is, the kit came with steel bushings, and the car has rubber bushings on the UCAs. I thought they all had steel bushings. WTF?!?! Is this a difference between 6 cyl cars and 8 cyl, or did someone just screw somthing up in the past?
  2. Slantsickness
    Tucson, Az
    1975 2 Dr.
    OK, I figured it out. Moog makes a shaft kit that converts it to rubber bushings, and someone must have installed it in the past. This kit supposedly makes it impossible to use steel bushings again, so I'll probably need to get new control arms.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Moog referred to that as the problem solver kit. Solved the common squeaking bushing problem by converting to GM style upper control arm bushings.
  4. Jamie Miles
  5. Slantsickness
    Tucson, Az
    1975 2 Dr.
    Thanks, i'll look into that. There is a yard here, and I think he's got about 100 ford control arms on a rack, but if i cant find ones i like, i'll probably get those.
  6. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    man, I just encountered the opposite problem haha. I bought the rubber upper arm bushings from moog and now that I've taken it apart I realize that it has the steel ones. I really want the rubber ones but don't want to have to buy two new shafts. Does anyone know if I even have to replace steel upper arm bushings? I only saw the rubber bushings offered on rockauto when I was purchasing so I thought there was no choice...
  7. Bryant
    the rubber bushings are a retro fit to replace the steel bushings. the steel bushings are difficult to lubricate. the way you install them is by pressing the bushings into the threads of the controle arms. this destroys the threads and from then on you can only use the rubber bushings. so you should be ok with the kit you have.
  8. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    I think I'm going to see if rockauto will let me return the bushings. I'll cancel my order for the ball joints with advanced auto and just order whole new upper arms. I'm pretty novice and can see trying to squeeze them on there presenting more problems than it's worth. I wish rockauto's website had a disclaimer that the rubber bushings were for an aftermarket shaft mod and not for the original shaft if that is all that they sell. Looking at it I can't even figure out how I would screw in the retaining nut and washer into my current shaft if I just squeezed it onto the threads (IF I could squeeze it on)....
