urgent shift linkage help
Discussion in 'General Maverick/Comet' started by runeking40, Aug 11, 2010.
  1. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    ok i changed from an i-6 to a 302 and i am having problems with the colum shift linkage bracket not bolting on right. Dont say convert to floor shift because i went with the shorty headers so i would have to but what is the problem i am having
  2. Old Guy
    Old Guy Member
    Am going to start on my 4dr soon. Got the 302 in stalled with shorty headers too. Looks like a fabrication on the cross shaft and pivot ball will have to be done. Have always used floor shifters before but want this car to be a sleeper with three on the tree c4. Car has 39000 original miles on it.
  3. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    well i was thinking could i get a shift linkage off a 1978 ltd ii and have it fit
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    How much of the linkage do you need? I have the stuff I pulled off my 71 that I won't be using when it goes back together.
  5. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    well i dont know i had an inline 6 in it and that linkage is all there and its not working with the 302
    are they different
  6. maverick@heart
    maverick@heart Member
    Hendersonville TN
    1975 American Maverick, 1976 Mexican Maverick, 1973 Maverick
    There is your problem. The linkages are different.you need to get the proper one for a v-8.
  7. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    can one off a 1979 ltd ii work and this is automatic
  8. CaptainComet
    Did you re-use the transmission that came in the car?
    The reason why I ask ... if you got another trans and it was from a floor-shift car, the rod coming out of the trans that the linkage attaches to is flipped 180 degrees and has a bit of a different shape to it.
  9. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    nope it didnt it was a column shift 5 days ago same transmission different engine
  10. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    the bracket from the inline 6 doesn't fit on the 302 and the rod doesn't slip into the engine
    could i get one off the ltd ii and have that work it was column shift
