V-8 tranny crossmember
Discussion in 'Technical' started by wardf, Nov 12, 2002.
  1. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Has anyone else had this problem? I bought a V-8 crossmember but the bolt holes center to center is 12 1/4" apart and the holes in frame are 11 5/8" apart. I do have a 70 mav and I know that they didn't come out with V-8s until 71 but the holes are there. Is this a common problem?
  2. Earl Branham
    Lugoff, SC
    Ward; Yes, it is a problem on all '70 Mavs. You have to elongate the holes in the bracket, and also clip the bottom part to clear the pan frame. Not hard, just something else to do. Good luck,
    Earl
  3. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Thanks, thought maybe something was wrong with either the car or the crossmember.
