v8 6cyl spindle
Discussion in 'Parts Interchange' started by jean282, Nov 3, 2005.
  1. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    Are they any difference between v8 and 6 cyl disk spindle ?
  2. Mavaholic
    Assuming your talking about Mavericks and Comets only, and if both cars have disc brakes, then no, there is no difference.
  3. jean282
    jean282 Member
    Quebec, Canada
    73 comet
    thank for help.
  4. bmcdaniel
    And the earlier drum brake cars shared the same spindles, V8, I6, 4-lug, 5-lug were the same.
  5. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    Disc/drum
    So, all spindle sare the same within the same years? Drum or Disc does not matter? My question: I have a 72 Grabber with an I6 and front drums (4 lug), would I be able to find a set of 5 lug disc set up of (what years?) to fit my car?
  6. bmcdaniel
    Disc spindles are different than drum spindles.
  7. 1972Grabber
    SAN ANTONIO, TEXAS
    Drum to Disc
    I have access to a 1980 Monarch w/302 and C4. The discs and rear are 5 lug. I am under the impression that everything would swap from one car to the next, right.
    1) I know I would need the spindle, rotor and the brake caliper from the Monarch but would I also need the tie rod ends (or complete tie rod assembly) from it too?
    2) Would I need to take the upper or lower control arms to make it all bolt up?
    3) Are all the upper and lower control arms the same on the I6 and V8 cars?
    I am going to take the complete rear end from drum to drum also, unless someone knows if a Lincoln MKVII (7) rear with discs would work. Any thoughts on this one? I really prefer facts though. I will also be taking the proportioning valve for the front/rear bias of the disc system.
  8. bmcdaniel
    Use your existing control arms but get the outer tie rod end that matches the new spindle. I6s and V8s used the same control arms.
  9. Mavaholic
    All you need is the spindles and all the brake stuff bolted to it. Will bolt right on your a arms. Your tie rod ends should also work with no problems. Mine did.
  10. 1972Grabber
    SAN ANTONIO, TEXAS
    Thanks guys. I will go get those parts tomorrow (actually today) since I am on the Mid Shift right now.
