v8 engine crossmember
Discussion in 'General Maverick/Comet' started by koldham, Apr 10, 2012.
  1. koldham
    koldham Member
    Walnut Grove, Gerogia
    1973 Maverick
    im about to the the junkyard, what the heck does this thing look like and where does it do exactley?
  2. Acornridgeman
    Wisconsin
    The belly bar? Connects both sides of the frame below the engine to help stiffen up the uni-body. One big bolt threaded into the frame on each side of it to remove it. Save the bolts as they are unique to the design.
    The other V8 item is a transmission crossmember that supports the tranny. Special from the I-6 as it has 2 humps for the dual exhaust.
    Hope this helps. Have fun at the junk yard!
    :thumbs2:
  3. koldham
    koldham Member
    1973 Maverick
    do you have a pic of the enginecrossmember? i think its just like a piece of pipe with the ends smashed flat but i want to be sure
  4. Acornridgeman
    Wisconsin
    I don't have a pic handy, but that pretty much describes it. Round tubing bent into a short u shape and flat on the ends and slightly flat in the middle to clear the inner tie rods. Other Fords do not fit the Maverick as the frame width is different.
  5. classic ccg
    ringgold GA
    72 maverick
    here is the thing you need
      File size:
      563 KB
      40
  6. classic ccg
    ringgold GA
    72 maverick
    v8 transmission crossmember
  7. 71gold
    that's not for the transmission...
  8. maverick75
    He probably meant to upload a picture of the transmission cross member, but forgot to attach it to the post.
  9. classic ccg
    ringgold GA
    72 maverick
    it did not up load V8 transmission crossmember it will not up load
  10. maverick75
    If you've used the picture on another post before it will not let you upload it again.
    The forum does that for some reason.
  11. Acornridgeman
    Wisconsin
    Forum does that to save bandwidth and prevent duplicate uploads ... if it is already uploaded someplace here, just paste a link to it using the picture link (mountain and sun) ....... [​IMG]
  12. koldham
    koldham Member
    1973 Maverick
    so that looks like 1 1/4 tubing. i can probabley make my own
  13. maverick75
    That's what I figured, I just host them on another site to not waste the forums bandwidth/storage space :Handshake
    There's a guy on here that makes some, he also sells OEM ones for cheap.
    Check out the for sale section.
