v8 frame mounts
Discussion in 'Parts Interchange' started by newtoford, Jul 14, 2006.
  1. newtoford
    newtoford Member
    New Castle Delaware
    Iam putting a '71 Turino 302 into my I6 maverick so iam going to need some V8 frame mounts. Are maverick frame mounts the only ones that will work? Finding Maverick parts has become a "task" at the least, especially a v8 one. I may be able to get the mounts out of a 64ish fairlane if they work too
  2. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    There Is Some On Ebay
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    There are some Stang, Cougar, and Falcon frame stands that will swap in.
    From about 65 1/2 to 70.
    They don't look exactly like the Mav stands, but they are the same in function.
    The very early stuff like the Fairlane you are mentioning, use iron frame stands and 2 piece mounts. They will work too, but they either raise or lower the engine in a Mav... Forgot which. You will not only need the frame stands, but all the mount and isolator parts to do this conversion.
    The steel frame stands that came out in mid-65 fit like I said, but you still need to use the Maverick mounts with them, the one piece mounts for Stangs are set up for a wider subframe. You can still get the Mav mounts at any parts house though.
    Good luck
    Dave
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Crites has repop frame mounts for $99. The rubber engine mounts can be obtained through your local parts store.
    www.critesrestoration.com
